What are those connectors? Discovery 1 with ABS 98'
Old Aug 20, 2023 | 04:45 AM
kat1337's Avatar
3rd Gear
Default What are those connectors? Discovery 1 with ABS 98'
Hello, someone made a connection from rubber hose and worm hose clamps.. As I know theres 200+ bar in braking system and well... That's why my brakes are dead.
I'd like to get back to original connection. So could someone tell me what is the part that I've marked on the photo??
Old Aug 21, 2023 | 06:15 PM
Harvlr's Avatar
You should be able to find your parts here.
https://new.lrcat.com/#!/1231
Old Aug 23, 2023 | 03:46 PM
hrhoward's Avatar
Instead of where the coupler is there is a piece of rubber hose with hose-clamps, yes?
If the bubble flares are still there and the flare nuts are hanging out on the lines, all you need is a 3/16" coupler (union) with M10 x 1.0 threads for bubble style flares.
Probably find them in your local parts house.
But if the nuts and flares are gone, you will need to get some nuts and flare the ends.
Old Aug 28, 2023 | 02:02 AM
kat1337's Avatar
3rd Gear
I dont know how is that possible that this site has more precise diagrmas than more popular that I've visited. Thanks a lot that's all I wanted to know !!!
Old Aug 28, 2023 | 02:04 AM
kat1337's Avatar
3rd Gear
Yeah I need to dig deeper but thanks for your advice also. Honestly I've made this thread just to see If the connection that was originally there is elastic or stiff but seems that you guys gave me more info that I've needed
Old Aug 28, 2023 | 01:23 PM
hrhoward's Avatar
Pretty sure those are solid connections. Flexible hose is from bracket mounted on underside of body to top of rear diff.
Picture below only has one but with ABS, there should be two flex lines.
Old Aug 31, 2023 | 09:53 AM
jvarnadoe's Avatar
Harv,
That link you provided to lrcat is super useful! I've bookmarked that for future use. Thanks!
Old Sep 1, 2023 | 09:20 AM
whiskeynipple0088's Avatar
pretty sure the union location you show in the schematic is at the lower footwell/firewall on the (US) drivers side. that is where mine rusted out.
It is prolly best to replace all break pipe if these are rusted. as the rest are going to go soon
if you decide too replace all the hard lines..... post back and I will detail what I learned when I did mine
I sourced my parts at napa btw
dnbrown9
Dec 14, 2015 10:11 PM
Boduke2020
Nov 9, 2013 10:07 AM
Emperor_MA
Jun 18, 2013 07:55 PM
packkratt
Feb 19, 2012 08:40 PM
nickvillaume
Jul 19, 2005 01:52 PM
