Radiator Hose Leaks on 98 Disco
Old Jul 18, 2005 | 06:06 PM
nickvillaume's Avatar
3rd Gear
Default Radiator Hose Leaks on 98 Disco
I have a 98 Discovery that has recently begun leaking coolant. The leak was originally coming from a puncture in the large hose that comes directly out of the radiator. I temporary patched the leak using duct tape so I could drive the car home from my office (about 6 miles) and leave it until i could order a new hose. However, upon returning home, I found that a new leak was squirting coolant from another hose that about 4 inches long and is located jsut to the left of the big hose and comes out of the other side of the engine block.
I am thinking that my problem will be solved by ordering new hoses. These are the original hoses, so I am sure they are due for a change. But, I want to make sure that the punctures are not being cause by a problem with the pressure in the cooling system. My concern is that i will put on new hoses and still have problems with pressure.
Has anyone seen an instance where radiator hoses have become punctured by a build up of pressure in the cooling system?
Old Jul 19, 2005 | 12:51 AM
Bait's Avatar
Default RE: Radiator Hose Leaks on 98 Disco
You don't state mileage. Generally, hoses fail due to age not pressure. The cap will blow off before the hose.
Old Jul 19, 2005 | 08:32 AM
3rd Gear
It has 90K miles. As I mentioned, these are the original hoses, so I suspect that the issue is simply the hose as opposed to a pressure issue, but I want to be sure before I spend money on new hoses and risk destroying them due to an issue with pressure.
Thanks.
Old Jul 19, 2005 | 12:49 PM
MikeRover's Avatar
You also didn't mention geographical location.
High Temps and age are a certainty for hose leaks in a Disco.
I also have a 98 and have replaced one hose already. I'm getting ready to take the plunge and replace all the hoses[:@]
Just part of the mystique of a LR
Old Jul 19, 2005 | 01:52 PM
mikemeyer0's Avatar
if you are having pressure problems you might have a blown head gasket.
Spencerfitch
Sep 27, 2020 12:17 PM
D2 2003
Nov 7, 2017 07:41 AM
FlyingZebra34
Apr 22, 2013 12:07 AM
discoboy
Dec 20, 2012 02:24 AM
c a redding
Oct 21, 2012 05:02 PM
