Wheel Bearing Removal
Old Jul 11, 2010 | 01:14 PM
AK Rover's Avatar
Default Wheel Bearing Removal
I finally got the hub removed my Series 2 and now I'm having trouble removing the bearings from the hub. What's the trick? The outer bearing came right out but the race is still in the hub and the inner bearing won't move. Do I need to remove the seal looking thing behind the inner bearing and drive it out that way? How do I remove that?
Sorry it's not about a Disco but the "other LR" section doesn't get visited very often. And I'm working with the same technology as the Disco axles, just 40 years older.
Old Jul 11, 2010 | 06:15 PM
AK Rover's Avatar
Got the bearing and seal out. Now just have to figure out how the remove the half shaft from the other side.
Old Jul 11, 2010 | 08:42 PM
antichrist's Avatar
Front:
Remove the hub, brake backing plate, then stub axle. Pull out the half shaft.
Rear:
Undo the drive flange bolts and pull out the half shaft.
If you're replacing the hub bearings also replace the race.
If you're not replacing them, the bearings need to be kept paired with their respective races.
Old Jul 11, 2010 | 08:57 PM
okdiscoguy's Avatar
Yeah, what he said.
Grlica
May 1, 2013 06:13 PM
Harvard
Jun 18, 2009 07:32 PM
sdsilvere38
Sep 16, 2008 09:32 PM
Aquaholic
Jun 15, 2007 10:30 AM
btp226
Jun 21, 2006 05:35 PM
