whistling and or whining
Old Dec 14, 2014 | 06:21 PM
Cookse7's Avatar
Default whistling and or whining
i don't quite know how to explain my driving experience with my 96 discovery it has the 5.0 and an automatic. i know for a fact that its front swivel joints need repaired but i don't think that is where that noise is coming from. i also know that the transmission cooler lines and the engine oil cooler lines are leaking and need repair. i'm going out on a limb when i say i think the noise is coming from leaky seals but it could be i guess i don't know. the last thing it could be is the transmission or gearbox itself. another thing is the vacuum bulb that controls the cruise control is broken. it does get louder as i put more pressure on the throttle and the noise is constant.
Old Dec 14, 2014 | 11:46 PM
TOM R's Avatar
I would start checking fluid levels
Mine has a whine cause I need to swap out the power steering pump, they are known to go bad
Only things that should whine are trans, PS pump, maybe alternator
I reiterate check the fluids in diffs transfer case etc, its easy to burn up these things from little leaks, transfer case will lock up
Old Dec 15, 2014 | 02:01 AM
Cookse7's Avatar
turning the wheel creates its own noise, so the power steering pump is a highly likely culprit i'm not really driving it much right now so i'll start investigating that as i go on and keep fixing my disco.
Old Dec 15, 2014 | 02:49 AM
TOM R's Avatar
Video the sound helps
Old Dec 16, 2014 | 01:34 PM
Trickymonk's Avatar
I've had an alternator and power steering pump whine. The last time I heard a similar noise, however, it turned out to be a failing belt tensioner. It gave out at lunch one day throwing the belt off. I managed to make it home before the truck overheated too bad. Easy fix, but I'll throw that out as a possibility.
gkubina
LR2
Jul 17, 2011 04:04 PM
kpl1228
Nov 8, 2010 02:04 PM
Classklown90
Dec 3, 2009 07:53 PM
lowill
Mar 10, 2007 02:26 PM
Snowman
Feb 24, 2007 05:24 PM
