Widest tire size for lifted Dico
Old Mar 14, 2014 | 12:36 PM
CUpgt's Avatar
If you go with skinny tires make sure to get as many jerry cans and lights as you can fit as well as limb risers
Old Mar 14, 2014 | 12:45 PM
EricTyrrell's Avatar
Wide tires are for flotation. There's only two surfaces that benefit from flotation. One is snow deeper than can be driven through. This is why arctic trucks have huge tires, but you'll have a hard time fitting tires big enough to make a disco float on snow. Instead you'll end up in the middle, not good at anything. Sand is another surface where flotation is helpful to some degree.
For shallow snow and most other surfaces, skinny will produce higher psi and cut through soft layers to hard layers below where the traction really is.
Old Mar 14, 2014 | 01:02 PM
CUpgt's Avatar
That's why the minimum tire you see is 12.50 for an aggressive purpose built truck. Aired down to single digit air pressure for the largest contact patch possible. Guess we've had it all wrong.
Old Mar 14, 2014 | 01:50 PM
HammerFit's Avatar
Well that was a good argument on both sides. It depends on what you want to build for a purpose. I use my truck for DD and I live on the coast. The worst problem we have is soft sand. So sounds like I need the widest, best tire that will fit with spacers and lift that will not kill my axles, diff, etc. That being said sounds like 2857516 on a stock wheel is the ticket.
If there is potential for a wider tire than that, that accomidates the above Im listening to you vets. And thanks in advance for all the info. Now where do I find spacers that freakin big? Just left the parts store, the biggest they had were only 1/2" thick.
Old Mar 14, 2014 | 01:51 PM
HammerFit's Avatar
Originally Posted by FantomRover
I've got 285/75r16 33x11 with stock alloys on a 2" lift. I run 1.5 wheel spacers in the front
Where can I find that spacer?
Old Mar 14, 2014 | 02:25 PM
fishEH's Avatar
These are what I run.
eBay: http://pages.ebay.com/motors/link/?n...d=390784308322
No problem with them not being hubcentric.
Old Mar 14, 2014 | 04:43 PM
265/75/R16 and 255/70/R16 are good options
Old Mar 14, 2014 | 05:23 PM
HammerFit's Avatar
Awesome thanks just ordered them
Old Sep 24, 2020 | 12:20 PM
Titans34187's Avatar
7th Gear
Default Tires and lift
Originally Posted by HammerFit
I have a 98 Disco with 3" lift. Currently have 2457516 BFG AT on stock wheels. The tires look like toothpicks with the lift. Want a tank look. What is the largest tire that will work with wider wheels. I was looking at Nitto 2857017 w 9" wheels Was told that was too big. Would spacers help?
2002 Disco II- 4” old man emu suspension lift w/ 35” tires on stock 15” rims
instg8r
Feb 3, 2019 05:00 PM
me 2
Jun 23, 2013 12:53 AM
BradHall
Dec 2, 2007 04:49 PM
grrRover
Jun 2, 2005 07:48 PM
958mtm
Dec 13, 2004 05:41 PM
