wierd idle issue
Old May 17, 2014 | 01:21 PM
HammerFit's Avatar
Default wierd idle issue
Ask my mechanic about this while it was having tranny replaced. They said they couldn't replicate the issue. Makes sense cause it only happens after it has been driven for some time (maybe 15 minutes or so)
When its cold, cranks right up and idles pretty high. After warming up idles back down where it should be. But after driving it for awhile it doesn't want to idle at all. It will just shut off. It will crank right back up but just keep shutting off unless you feather the pedal.
Does that sound like a vacum leak? Any clues what to look for?
Old May 17, 2014 | 04:30 PM
TOM R's Avatar
Codes?
Check your vacuum lines
Fuel temp switch?
Crank sensor getting hot?
Old May 17, 2014 | 09:40 PM
OverRover's Avatar
Clean the stepper motor(IAC Valve)
Check/clean throttle plate
Bad Amp module??
SDinDS
Sep 4, 2010 09:07 PM
Jeff g
Jul 15, 2010 06:51 PM
imarockstar
Feb 22, 2010 12:19 PM
RamblingMan
Jan 23, 2008 11:49 PM
Randy Lover
Sights N Sounds
Aug 6, 2005 07:39 AM
