will a D2 rear view mirror fit a D1 mount?
Old Sep 22, 2014 | 03:53 PM
philwarner's Avatar
Default will a D2 rear view mirror fit a D1 mount?
I may be getting my cracked windshield replaced Wednesday and need to know if they should re-mount the rear view mirror bracket.
I haven't gotten a D1 mirror yet and need to know if a D2 rear view mirror will fit the D1 bracket in case I decide to go that route instead.
Old Sep 22, 2014 | 06:10 PM
Paul Grant's Avatar
If I'm not mistaken, the '99 DII mirror will work directly with the '96-'99 DI connector and socket. The later DII mirrors had compass or homelink features and the wiring was different. As are as attaching to the window, any of them should work.
Old Sep 22, 2014 | 06:15 PM
TOM R's Avatar
Put a GM mount on it and you can get a Saturn mirror like I did with temp and compass just change the plug and add the temp sensor behind the grill
Old Sep 22, 2014 | 08:42 PM
Buddy Lee's Avatar
DII mirror works just fine I have one with the compass. I can't remember if I had to splice any wires or not but the window mount is the same.
Old Sep 23, 2014 | 07:55 AM
jimvw57's Avatar
Added the DII mirror to my D1. had to play with the wires a bit to get the mirror to work right. Has been working great for a few months now.
Old Sep 23, 2014 | 10:49 AM
notny41's Avatar
Yes, I'm pretty sure mine is a DII mirror as well. It has the compass and auto-dim - I will check the wiring for you when I get home - it works perfectly and used the same mount.
Old Jul 20, 2016 | 04:24 PM
Roger B.'s Avatar
never got home? ;-)
Ibought a mirror with compas, auto-dim and three buttons for homelink on ebay. Was sold as p38 mirror (but never seen a p38 with compas) and should fit in a D2 as well...
in the base of the mirror there was a black 2x5 pin connecor with a red, a brown and a grey wire..
In my RAVE for P38 i can find a autodim mirror, but that has a different connector.
In my RAVE for D2 the electric rearview mirror is not mentioned in the schematics.....
SO.... now I need to know what signals go to these three wires.... I assume brown= ground, red is 12V supply and grey is switched power or something like that.... but would like the be sure
Old Jul 20, 2016 | 07:31 PM
aemnky606's Avatar
Went out and looked, here is what worked for me. I did not have the colors you have but I used a 2000 D2 mirror
D1 Mirror
Grey Green/Brown
Black/Black
White Green/White
Old Jul 21, 2016 | 08:51 AM
hrhoward's Avatar
Roger,
This is what worked for me.
D1 to D2 rear-view mirror wiring
Old Jul 22, 2016 | 10:39 AM
Best4x4's Avatar
Yep I so love my non leaking D2 mirror in my D1!! Works great and it's just 3 wires. Constant 12v, keyed 12v, and ground if I'm not mistaken.
