Window lift ecu
Old Oct 19, 2017 | 04:03 PM
dicksoutforharambe's Avatar
Default Window lift ecu
My rear windows won't go down so I did some soldering on the window lift ecu and now the blower for the heater doesn't come on. Does anybody know if the ecu also controls the blower motor, or should I be looking somewhere else? Thanks in advance.
Old Oct 20, 2017 | 01:40 AM
jimvw57's Avatar
ECU does not control the blower motor. I would suspect the switch, but the fan is located down by where the ECU is located so you may have bumped a wire. Does it work on any of the speed? If not, I would check for a fuse in the fuse panel or under the hood fuse block.
Old Oct 20, 2017 | 07:44 AM
Your probably right about me bumping something. I'm gonna take it apart today and have a look. I just wanted to make sure it wasn't connected to the ecu. Thanks.
twoxred
Oct 4, 2021 07:07 AM
llPANCHOll
Jul 14, 2009 11:10 AM
Nfbeckman
Jul 13, 2009 11:51 AM
ajordan_0012000
Oct 16, 2008 06:44 PM
rravenn13
Aug 21, 2007 05:32 PM
