Windows And buzzing from glovebox
Old Apr 29, 2012 | 12:08 AM
EricTyrrell's Avatar
Default Windows And buzzing from glovebox
My windows just started randomly not going up or down. Instead I hear a buzz from the glove box area when trying to raise or lower. I know of problems with the window lift ECUs but not buzzing. Anyone know what this sound might be?
Old Apr 29, 2012 | 07:55 AM
A relay related to or part of the ECU, once you locate it by touch or sound, then it will be easier to think about what kind of ground, latte in the switch etc. is causing the relay to interrupt the supply voltage to the coil (which makes it a buzzer). Careful of this high dollar cardboard under the glove box. BTW, once all that is off it is easy to drop heater fan to clean out any leaves and junk. The common ground for the up/down switches must be somewhere near the console, could also be loose.
Here is pix of E303 the common switch ground
File Type: pdf
mrossipir
Jul 4, 2014 10:29 PM
Duke
Dec 31, 2010 08:34 AM
Torancis_LR
Dec 28, 2009 05:21 PM
eurosport1
Nov 30, 2008 11:07 AM
VB_Rover
Jul 20, 2005 02:43 AM
