windows still not working
Old Sep 20, 2010 | 01:54 PM
pwr198's Avatar
Default windows still not working
tried resoldering, tried the jumper method still nothing, any other ideas out there>>>>>
Old Sep 20, 2010 | 02:13 PM
okdiscoguy's Avatar
switches, including the lockout switch.
Do the fronts work?
Old Sep 20, 2010 | 02:31 PM
Danny Lee 97 Disco's Avatar
I had one of my switches go bad (driver window), a quick swap with one of the other switches confirmed it was indeed the switch. A friend had a spare in his parts Disco.
You can also jumper 12 volts DC directly to the motor to check it out.
You could do readings with a meter.
Old Sep 20, 2010 | 04:17 PM
Henrici's Avatar
Originally your pulled your ECU because your back windows weren't working now all of them don't work, correct? If that is the case then it must have something to do with ECU or how it was removed/installed. Is it connected correctly? Did you blow any fuses? Did you dislodge any wires from the harness while connecting/reconnecting?
________
vaporizer store
Old Sep 20, 2010 | 06:54 PM
pwr198's Avatar
fronts are working but back are still not. maybe I'll just go without.????
Old Sep 21, 2010 | 02:43 PM
Henrici's Avatar
I mean you could go with out the backs working you don't sit there, ha ha. But I re soldered my board then put it back in, no luck. I tried that jumper thing, no luck. So I figured I'd try one more time and re solder the whole board before I put everything back together. Well that time it worked fine. I did find the driver's side rear window motor was disconnected die to the window regulator roller being busted (gotta love the previous owner's solution).
________
Mercedes-Benz Type 300 picture
Old Sep 21, 2010 | 04:49 PM
Did you carefully reflow ALL the solder joints on the ECU board. Mine had a couple of points where there were hairlinee cracks that at first glance were not evident. Pressing on the component leads lightly showed the problem.
Mine were intermittent before, now they work fine.
JERMAINE
Oct 5, 2010 08:51 PM
rebelman
Sep 7, 2010 08:08 AM
sickvehicle
Jul 16, 2010 03:44 PM
Spencerfitch
May 28, 2010 06:34 PM
quattro
May 29, 2008 12:56 PM
