wipers won't shut off
Old Feb 28, 2021 | 11:05 AM
dicksoutforharambe's Avatar
Default wipers won't shut off
Hey guys Im having a problem where my wipers won't shut off unless I pull the fuse out. Im thinking that water is running down the A pillar and shorting out a relay or something. Was wondering if anybody else had this issue and how they fixed it. Thanks in advance.
Old Mar 2, 2021 | 07:33 PM
Hey guys, thought I’d post an update on the wipers. The weather was halfway decent here in Cleveland today so I went out and messed around with it. I took the wiper motor apart and cleaned the contacts and surfaces that they rub against. It seemed like there was a bit of grease in there. Anyway got it all sorted and put back together in less than an hour and it seems to be working fine. Hope this helps anybody if they’re having an issue.
Old Aug 17, 2021 | 12:42 PM
John deere's Avatar
4th Gear
Hi guys, my disco wipers have developed a mind of their own with periods of unstoppable front wipers that I’ve resorted to pulling the fuse to disable. The control stalk has zero effect during the fault condition
has anyone experienced anything similar that they’ve managed to remedy themselves?
the control relays have been swapped with zero effect & the stalk has been unplugged but the fault still remains.
I’m now at a bit of a loss as to where the fault may lie.
Phil
Old Aug 17, 2021 | 03:20 PM
I had the same problem. I replaced the wiper motor with a used one that I bought off eBay and it’s worked fine ever since.
Old Aug 17, 2021 | 07:41 PM
JohnZo's Avatar
My wiper problems were solved by taking the motor/gear assembly apart and polishing the electrical contact surfaces, like dickso above.
Old Aug 18, 2021 | 04:40 AM
John deere's Avatar
4th Gear
Thanks for the info guys, I’ll check it out
Phil
Old Sep 1, 2021 | 09:03 AM
John deere's Avatar
4th Gear
After much hair pulling I’ve removed the BCU & sent it to ecu repair to let them have a go at repairing, the wiper relay was being permanently fed by this module.
John
Old Sep 1, 2021 | 11:46 AM
stillruns's Avatar
Move to Alabama this time of the year and you will need them most days.
austinlandroverbill
Feb 9, 2022 09:38 PM
ge234
Jan 25, 2016 02:12 PM
Andy2Rover
Nov 27, 2014 04:53 PM
Mrcreeper3435
Oct 17, 2012 05:35 PM
BMWLR
May 27, 2006 04:34 PM
