wires running from the fuel pump of a '95 discovery
Old Mar 19, 2011 | 05:20 PM
james taylor's Avatar
6th Gear
Default wires running from the fuel pump of a '95 discovery
does anyone know where the wires are routed between the fuel pump relay and the fuel pump? if so, please help
Old Mar 19, 2011 | 09:17 PM
roving patrol's Avatar
Are you asking about the harness that connects to the fuel pump? If so, it's goes down under the truck and routed to the starboard side. If you are asking about the routing of wires in the fuel pump itself, then they consist of 4 wires that's routed between the leveler and the relay and goes out to the socket.
Best regards
Erwin
Old Mar 20, 2011 | 05:36 AM
6th Gear
Default fuel pump wiring harness
i am talking about the wires that connect to the top of the pump and seem to disappear into the truck frame. You said the "star board side", what is that? The wires run underneath the vehicle, or inside somewhere? and are they connected to something else other than the fuel relay? Want to know where to look for these wires. My relay and pump have both been tested, and they are both good, but something in between them draws electricity when the vehicle is off.
Old Mar 20, 2011 | 06:34 AM
6th Gear
and most of the times when i start it ( sometimes right away, sometimes in a few minutes), it idles up and down from normal idle speed to almost dying. sometimes the fuel hand reads empty and the fuel light is on. any ideas?
Old Mar 22, 2011 | 09:38 AM
groundandpound's Avatar
From the Tech Sticky:
https://landroverforums.com/forum...d.php?p=152377
Old Mar 22, 2011 | 06:53 PM
Banzai Jimmy's Avatar
I just researched my fuel gauge/light issues recently. Turns out the wiring between the point where it exits the body on the rear, driver's side and makes its way across and over to the tank had several nicks in most of the wires - the purple w/white tracer was heavily damaged (only a few strands were still connected). Went in and properly repaired several sections of wiring (remove damaged section, solder in new section, cover soldered areas with shrink wrap, and bundled the sections and replaced missing wire loom cover) and haven't had a problem since.
Since then, a mystery stalling when real cold out (like under 20*F) and the engine was cold has gone away. I'm hoping it stays that way!
Travelor
Sep 24, 2015 06:11 PM
Murph2121
Dec 9, 2013 02:57 PM
crumleyjc
Jul 13, 2012 01:57 PM
JumPeR04
Apr 7, 2011 09:52 PM
Shaggy
Nov 22, 2008 06:53 AM
