Wiring Reverse Lights to Rear Rack
Old 10-07-2019 | 05:50 PM
Toran's Avatar
Default Wiring Reverse Lights to Rear Rack
Hello All,
I have a set of LED lights I would like to connect to the reverse lights.
Can I do all the wiring from the rear of the truck? Would I simply be taping the LED lights into the factory reverse light wire and than grounding them?
The LEDs are (2) 7inch lights that are 36watts. 72watts combined dived by 12volt is 6amp.
T.I.A.
Old 10-07-2019 | 08:05 PM
fishEH's Avatar
I wouldn't recommend "taping the LED" lights.
Do you want to always have those lights come on anytime you're in Reverse? Backing out of your driveway, blinding people in the mall parking lot, etc? Or just wire them to a switch when you need them?
Either way it's best to wire in a relay and have a switch or the stock reverse light be the trigger, with the relay pulling power from the battery.
Old 10-07-2019 | 10:32 PM
Toran's Avatar
Auh I see your point about blinding people at mall parking lot.
Best to wire this up to a switch.
Thanks
Alex_M
11-24-2014 07:03 AM
30more
06-29-2012 12:49 AM
03discoman
03-06-2010 09:09 AM
azoverlander
09-19-2009 04:20 PM
Disco Fuego
03-04-2009 08:00 PM
Quick Reply: Wiring Reverse Lights to Rear Rack
