Worth it to setup Disco 1 4x4?
Old May 19, 2011 | 09:52 PM
  #101
jafir's Avatar
The first trick for me, would be finding one I could afford.... and then not using that same money to buy and ex-mod 110 instead.
Old May 19, 2011 | 10:02 PM
  #102
Mountain Goat's Avatar
I like the approach and departure angles on H1s. Breakover angle, not so much:
YouTube - ‪Hummer H1 Rock Crawling Water Fall at Hidden Falls‬‏
Since we've had some discussion of solid axle vs. generic independent suspension:
YouTube - ‪WarPath New Mexico Extreme Rock Crawling Part 1‬‏
Also, let's see anything with independent suspension do this:
YouTube - ‪land rock crawling‬‏
Old Jun 7, 2012 | 04:16 PM
  #103
jschin79's Avatar
Default GM truck vs Discovery
Use the money you intend to spend on aftermarket parts for the Discovery as a downpayment for your next truck....
Seriously, I've had trucks and SUV's, but none of them has been able to go where I have taken my Discovery 2 stock!
It's requires finesse and technique driving it. You cannot just give it the gas (or any other vehicle) uphill with the hope of making it uphill or through mud.
Its different than any other GM vehicle. Go to a Overland Experts and learn how to drive.
Old Jun 7, 2012 | 05:44 PM
  #104
psykokid's Avatar
Old Jun 7, 2012 | 07:24 PM
  #105
fishEH's Avatar
Nevada Ben got harassed pretty well on Pirate and Dweb and split a long time ago.
Old Jun 7, 2012 | 07:37 PM
  #106
antichrist's Avatar
Yeah, I was sorta sorry to see him go, he was pretty funny.
Old Nov 11, 2012 | 05:04 AM
  #107
RoadDisco's Avatar
3rd Gear
Talking Discovery 1 ES 300tdi 430000 km's
My Discovery 1 is brilliant it's a '98 model and it's been on the trail (rough stuff) and survived. Been washed down river in the heavy rain, and survived.
The plastic bits on the dashboard are a bit flimsy, but then a bit of tape or strong glue and its good to go.
All of the mechanical parts are easy to fix if they go wrong, if you are doing a lot of trail driving then think this is a 14 year old truck. The bushes are old; the shocks are old; the springs are old; the engine mountings are old. The water pipes are old.
Replace all of these with new.
Then see how this truck will deliver on the trail.
My Discovery 1 was the executive version in South Africa, with all the drop down plastic under the bumper, for the trail this must be taken off, it gets ripped off anyway the first time you go over some rocks, take off the std tow hitch assembly, it's too long and digs into the ground. Fit a front bash plate and sump guards.
If you intend to do some water driving. Remove the security system box, and re-wire (you will be stuck in the wild if this gets water in it)
And fit a air box pipe that will be above the water line.
Remove back seats, (they add weight) Take off spare wheel from 5th door bracket and put inside where the back seats used to be.
Do all of these things and you will have a very comfortable 4x4 for trail driving.
PS: Really good tyres make a difference too.
Old Nov 11, 2012 | 10:17 AM
  #108
Michael M. Koch's Avatar
I... think the dude's probably made up his mind by now.
TRIARII
Jan 12, 2015 05:34 PM
LeeJames
Oct 2, 2009 03:09 PM
R_Lefebvre
Jan 25, 2008 09:26 AM
trini defender
Defender
Dec 7, 2006 12:12 AM
Butch
Appearance & Camping Set Ups
Apr 24, 2005 05:49 PM
