Wrong distributor in '95, Pertronix connections
Bought a very nice 1995 Discovery. Totally flat accel, found vacuum advance disconnected + broken. In checking distrib numbers (35DM8), it was distributor that fits '83 carbureted one. Have new correct dizzy for this truck, but connectors are different. I can trace the blue and red back to the ignition module-- would this be the correct path? Is the red + and the blue negative and then just connect them to the appropriate poles on the new dizzy? Leave everything else as-is? Many thanks!!
if you are using the Pertronix dizzy....I'd use the Pertronix module mounted on the dizzy and eliminate the oem one . Originally the Rover modules were distributor mounted , but later moved forward away from the heat...
See pic for the parts/numbers, you can get them here > https://www.fcpeuro.com/products/lan...scovery-hls101
Have already done plugs wires, etc. This truck is very satisfying to work on-- near showroom condition w/ 105k, brand new Michelins. Ran smooth as a watch, but dead flat accel. I think it will come along beautifully w/ a bit of work.
