What harness connections are these?
Old Oct 13, 2010 | 02:59 PM
Arizona man's Avatar
Default What harness connections are these?
I have two connectors that I can't find anything to plug into. One is the orange connector by the coolant reservoir and the other is a two prong white sensor by the passenger firewall.
Old Oct 13, 2010 | 03:27 PM
Second one, white, is an 02 connection, not sure what the first harness includes, why do you ask?
Old Oct 13, 2010 | 04:20 PM
I just replaced my engine and have cam sensor codes, evap codes, and tps codes coming up. Just wondering why I can't find the other end of these connectors coming off the motor.
Old Oct 14, 2010 | 04:45 PM
The service manager at Royal Jaguar Land Rover of Tucson looked at the photos and said both of these come unplugged from the factory. I think what happened is I fried all my sensors when I overheated my last engine and tried to reuse all of them. I'm just going to have to replace every single sensor. No big deal, it will probably be less than $500 altogether and everything will be brand new.
Old Oct 14, 2010 | 06:57 PM
lordmorpheus's Avatar
That sounds extremely fishy. How hot did you get this engine to damage every sensor on it? Did it catch on fire, or melt?
Old Nov 20, 2010 | 05:07 AM
Trying to figure out where to start. Every sensor hopefully isn't bad. I think one is setting off the others. As of right now the codes are cam sensor, tps, MAF, O2 x 2, two evap codes, and the M & S lights are blinking. It idles high at 2k rpm at startup then drops down to about 4-600 rpm and does not respond well to throttle. I replaced TPS last week with no results, it still bogs out when I give it gas. My next best idea is to replace the MAF sensor. Any help appreciated.
Old Nov 20, 2010 | 05:16 AM
On a further note, I just looked at a ford taurus that was acting the same way and the problem ended up being the temp sending unit. I will likely replace that as well if the 4.0 has one since the coolant reservoir was boiling over after about ten minutes of idling.
theswede
Oct 29, 2015 01:05 AM
VikingDiesel
May 26, 2009 02:43 PM
apcollin
Sep 21, 2007 11:07 AM
rovernbama
May 15, 2006 03:03 PM
