Wrong Gas Cap?
Old Apr 29, 2012 | 10:32 AM
Default Wrong Gas Cap?
Is this gas cap for the pre-AEL D1? My 97 D1 has a round canister, not rectangular, and code number on plate shows it to be pre-AEL. Have been chasing 1447 and 0446 codes. Changed canister and valve. Vac line clear to engine and throttle body port cleaned out. Gas cap makes big "woosh" when removed. At some point in the past the ECU was swapped from donor vehicle (unknown what version evap). Gas cap from unknown truck, might be oem, might be a swap. Has "12" in the center of the yellow part.
As always, thanks for your help and guidance.
Old Apr 29, 2012 | 10:36 AM
I dont think it really matters Buzz.
I think the non-AEVAP and the AEVAP use the same gas cap.
However you could buy a new one just to be sure, they sell for about $10 at your local parts store, just make sure it is a NON vented gas cap.
Old Apr 29, 2012 | 11:00 AM
priceg's Avatar
I think you are chasing your tail untill you verify the calibration number on the ecm.
Old Apr 29, 2012 | 11:28 AM
jafir's Avatar
Advanced evap gas cap is tethered. But like spike said, I don't think it really matters.
alowrun
Apr 12, 2011 09:36 PM
cocca
Jan 26, 2009 08:40 PM
Camdisco24
Apr 29, 2008 11:14 AM
dammad
Apr 21, 2008 10:48 PM
Bob2003Discovery
Mar 27, 2007 11:57 PM
