XZLs
Old Apr 3, 2014 | 09:27 PM
ZGPhoto's Avatar
I think we have a set here I can mount and test
Old Apr 4, 2014 | 04:33 AM
antichrist's Avatar
My 7.50R16 G90's were fine with a 1 1/2 - 2" suspension lift and 2" body lift, no cutting needed.
Wheel spacers on the front help a lot with turning radius.
Old Apr 4, 2014 | 10:15 AM
jafir's Avatar
Originally Posted by ZGPhoto
I'm trying to avoid any cutting really... I know they had to camel cut during the trophy for the 7.5r16s but..eh... this thing is pretty perfect.
I think that guy with the Camel Trophy disco confirmed for me that they are actually 7.00-16. I've seen both mentioned, but I'm guessing the 7.50r16 were on the defenders and maybe series.... so you'll probably have to do... something... to make them fit. I think someone mentioned spacing the bottom of the panel out if you don't want to cut? I'm not sure I'm remembering correctly.
Old Apr 4, 2014 | 10:17 AM
ZGPhoto's Avatar
They were indeed 7.0x16 on the trophy, sorry!
Old Apr 4, 2014 | 11:11 AM
fishEH's Avatar
We're talking about 31" tires here right? Seems like any 1.5" lift should be adequate. As Jafir mentioned, there's a write up in the Tech section on Dweb about pushing the rear quarter panels out to accommodate larger tires.
Old Apr 4, 2014 | 11:24 AM
ZGPhoto's Avatar
They're roughly 32"
Old Apr 4, 2014 | 12:06 PM
EricTyrrell's Avatar
I run 235/85 which is a little taller and wider, plus 12mm extra offset from the wolf wheels and all I had to do before the lift was a camel cut.
