yet another issue
I have those tires too, looked around under the truck after every drive because of it for awhile.
on
So, lets get away from the rocks and back to what is most likely starting to fail. When was the last time you did a complete front diff. service, bearings Swivel fluid, seal and a setting of the preload? You may be out of swivel oil, causing the cv joint to talk to you. There is a slight chance, depending on it mileage and how low the fluid is, that you may prolong it's death by filling both swivels.
