***UPDATE*** Service Engine Soon Light on and motor misfiring
Old Jun 15, 2009 | 06:19 PM
richey50's Avatar
Default ***UPDATE*** Service Engine Soon Light on and motor misfiring
Hello,
Just want to update you all on my sister's car which had the Service Engine Soon Light and misfire with the following codes P0130, P0171, P1171. After searching online for what the codes ment I found the following 2 sites;
http://www.robisonservice.com/servicedep/rover_obd2.asp
http://www.obd-codes.com/trouble_codes/landrover/
I also talked to a Land Rover Service Rep and I finally ended up changing the front Pass. side O2 Sensor and that corrected all the problem, so I hope this helps you guys.
Old Feb 6, 2011 | 10:04 AM
mbquimby's Avatar
7th Gear
I have the exact same codes. I guess i'll start with the front passenger 02 sensor. How did you know which sensor to change?
BlackDiscoII
Jun 2, 2012 08:58 PM
G Reeves
Oct 17, 2011 11:38 AM
richey50
Jun 11, 2009 11:59 PM
Bob2003Discovery
Jan 22, 2009 09:12 PM
mr_boondoggle
Freelander
Jan 2, 2009 09:32 AM
