'00 Disco SII Rear Door Issues
Old Sep 25, 2006 | 05:01 PM
CPDieker's Avatar
Default '00 Disco SII Rear Door Issues
I am having some problems with the rear door of my Land Rover. Last night I went to open the rear door and the door never unlatched. I found that I had forgotten to unlock the door, so I cycled the locks (lock and then unlock) and attempted to open the rear door. It never unlatched. I can operate the handle completely with no resistance. This is day three of this problem.
Has anyone had this problem or know of a possible fix? How difficult it might be? Where to start looking? Please help. Thanks.
Patrick
Kansas, USA
Old Sep 25, 2006 | 05:13 PM
Default RE: '00 Disco SII Rear Door Issues
Remove the Rover emblym from the outside license housing and spray the latch with some oil, you should be fine.
Mike
Old Sep 25, 2006 | 05:16 PM
geoman's Avatar
It is most likely a broken latch --something we do see at the shop from time to time. And it is a pain to gain access to when the door is shut. You have to unfasten the rear panel from the inside of the vehicle (where the sub-woofers are) the best you can, and by "feel" manually trip the latch to open the door. The part is a dealer-only item.
Regards,
Geoman
www.eurotekapg.com
Old Sep 25, 2006 | 05:54 PM
CPDieker's Avatar
Geoman-
When is the exact part name so I can order if needed from the dealer?
Thanks for your help.
Old Sep 25, 2006 | 08:37 PM
geoman's Avatar
It is simply referred to as the door latch assy.
Geoman
RoverBum
Feb 15, 2012 01:45 PM
teramera
Mar 21, 2009 09:38 AM
jh063078
Mar 21, 2008 10:19 PM
CPDieker
Oct 17, 2006 03:28 PM
CPDieker
Jul 10, 2006 06:30 PM
