01 DII Doors wont lock or unlock
Old Jul 4, 2015 | 01:58 PM
hacksaw830's Avatar
Default 01 DII Doors wont lock or unlock
Don't have a remote but only driver door will unlock with manual key, switch on dash doesn't work but I can hear the locks clicking when I hit unlock I can hear the IDM click when I hit lock and unlock, so far I have replaced the dash switch, the IDM and the driver door lock actuator from my working 99 DiscoII and I get the same thing. the only way I can lock all of my doors is to go to each door and manually push the door plunger down I have to crawl over the back seat to get the rear door the only way to unlock them is to unlock the driver door with the key and go to each door and pull the door pull to unlock the actuator because the actuator holds the lock down. Any more Ideas? how about the passenger front door would that cause a problem or maybe a ground somewhere, how about the under hood fuse box?
UPDATE Finally got the driver door to lock and unlock by replacing the driver door actuator and closing the door, it works with the dash switch but the other 3 doors and rear door will only click, is there a procedure to re-sync or program the passenger doors?
Old Jul 5, 2015 | 04:02 PM
abran's Avatar
My guess is bad luck, all the actuators are bad.
I think the cargo door one is the easiest to swap, so try that one first, if it works then you know you have 3 more to do.
I am not aware of any re syncing that needs to be done.
wynhd
Aug 28, 2012 11:33 PM
richierichrover
May 27, 2009 09:42 PM
russcan
Sep 14, 2008 10:45 AM
03LRSE7
Nov 30, 2007 09:56 PM
