another how to check transmission fluid
Old Jul 4, 2015 | 02:45 PM
dirtlord's Avatar
Default another how to check transmission fluid
its been about 6 months since i checked it. i take it around the block. leave it running in park go to check the fluid and its full i end up losing about a quart could have lost more if i didn't plug it. then tried it in neutral same thing. is it supposed to be in drive or what? i cant figure out where all that fluid came from.
Old Jul 5, 2015 | 06:28 AM
drowssap's Avatar
Running in park, even LR wouldnt tell you running in drive.
Old Jul 5, 2015 | 07:51 AM
antichrist's Avatar
You're supposed to check the level with the engine/gearbox at ambient temperature.
How To Check And Refill Transmission Fluid On Discovery 2 And Range Rovers
or page 10-18 in the workshop manual.
Old Jul 5, 2015 | 05:57 PM
OffroadFrance's Avatar
The quickest way I have found is to jack up the vehicle onto axle stands underneath front and rear axles so the wheels are 2 inches clear of a level garage floor. Start the engine and with your foot on the footbrake move the auto stick through all the range of gears a couple of times and then return it to P park. Undo the filler/level plug and top up the Dexron 3 asap until it overflows slightly. Re-insert the plug and run through the gear range again with your foot on the footbrake then return to P park and recheck the ATF level again and top up if necessary. Job done. Time taken about 30-40 minutes.
FlyingZebra34
Feb 22, 2014 05:39 PM
mirepoixmatt
Dec 26, 2013 12:19 PM
hriant88
Aug 6, 2013 05:09 PM
varlean
Freelander
Dec 18, 2011 09:30 AM
pizzaboy
May 11, 2011 06:56 AM
