01 disco 2 service engine light not working
Old Feb 2, 2019 | 08:14 AM
mln01's Avatar
Originally Posted by mollusc
pin #20 of connector 4 (c0637) on the ecm is the switched ground for the malfunction indicator light, so i guess it would actually be possible for someone to track down which specific wire that becomes, and cut it somewhere on its journey across to the instrument panel. apparently the wire is red/slate when it comes out of the ecm behind the fascia panels.
a piece of tape seems far more likely.
Seems to me that anyone with the skills to research and accomplish all this should easily have the skills to just fix the underlying problem!
Old Feb 2, 2019 | 09:12 AM
mollusc's Avatar
that was my thought too.
Old Feb 2, 2019 | 09:42 AM
The Deputy's Avatar
Not necessarily. If l was in the business of disabling check engine lights, especially on vehicles that were going to be sold, l'd disable the wiring system within a plug connection (breaking wire as close to terminal pin). This way, the wire just looks to be broken...could have happen on its own, at the factory, etc.
That's why folks use to burn out the bulb. If you removed the bulb (or cover it up)...tempering was obvious. But...a burned out bulb...who can you blame on that.
Brian.
Old Feb 2, 2019 | 10:05 AM
gurusonwheels's Avatar
8th Gear
well guys . took apart and someone removed the led at LED9 POSITION on the board .
anyone know of a comparable led replacement that i can solder in its place to make it work again ?
not sure what the specs was on the original led ...
thanks for your help .
Old Feb 2, 2019 | 10:13 AM
The Deputy's Avatar
Extreme tempering...obviously.
I'd take the printed circuit board to Radio Shack, maybe they could help you out. Granted, l'm not sure if they are still in business?
Brian.
Old Feb 2, 2019 | 10:55 AM
mln01's Avatar
Radio Shack? What's that? Ain't none of them around here no more ...
Old Feb 2, 2019 | 11:02 AM
Saturnine's Avatar
Pics of the cluster PCB with other LED's?
Old Feb 2, 2019 | 12:03 PM
Best4x4's Avatar
Yep no way in hell is anyone tracking down ECU wiring vs 6 phillips screws, some tape, or pliers, and call it a day.
At the dealership I do remember a beautiful Red Callaway P38 being traded in. It had an SES light on , and during the certified pre-owned program it was to be repaired to like new with no faults before being sold. Several ECU's later, and tons and tons of wire hunting the problem just wouldn't go away (reason it was traded in I'm sure). The tech working on it finally bypassed it via wiring, but a year later it showed up because it wouldn't pass inspection due to OBDII testing..... It was bought back if I'm not mistaken and the customer rode off in an 02 Westminster.
Old Feb 2, 2019 | 12:04 PM
Best4x4's Avatar
Those LED's really don't have any legs on them to just solder back on. How many miles are on your D2? I'd try to grab the PCB from a wrecked D2 and then just SYNC the mileage from the BCU to the Cluster.
Old Feb 5, 2019 | 05:28 AM
8th Gear
fixed it . ordered the led and re-soldered it on.
all is well now .
you can buy a 20 pack here order the color you need .
very very tiny .
Amazon Amazon
thanks
