01 disco P1300, P0303, P0302, P301
#21
#22
#23
#24
https://landroverforums.com/forum/di...t-82610/page3/
#25
#26
#27
#28
using Lucas cleaner in the ultrasonic, thinking it's too thick. is there a better cleaner that is less viscous?
getting the heads off of one of the salvaged discos, I am going to clean those and place the HG kit on those then swap it for mine. this should keep down time to a minimum.
#29
#30
The reason for those codes are these.
Injector failing or failed in cylinder 3
Open or short found in the wiring harness
Electrical connection that is poor
If you are getting misfire on cylinder 3, it could definitely be the injector 3.
