'02 Disco II: Transmission, axle and tranfer case oil check/change questions
on
Thanks, btw I will add whoever designed those fill ports must have a good sense of humor especially the transfer case fill hole that was a fun one to get off.
Next up change the ignition cables and then tackle the 3 amigos but I don't think they are going anywhere until I fix my broken wheel hub. Thanks guys.
As for the wires, who's wires will you be using and do you have secondary air injection.
I will be glad to help you with either.
Well my mechanic did but he is not a rover guy just a regular import mechanic though. He diagnosed it by pulling on the left front wheel when it was up on the lift. When you pull straight out on the wheel (perpendicular to the face of the wheel, parallel to the ground) there is about maybe 1/4 - 1/2" of play plus my steering wheel shakes a lot at medium speeds. Nothing else is loose on the front end to cause the shake and it goes away at high speed. Could that be something else?
Any play at the wheel is the bearing pooped, just done one of mine. A little less movement than you have, but easily noticable with the vehicle of the wheels. grab the wheel at 9:15 and 6 o'clock and wiggle, if theres play its had it......Mine looked like this when it was off.......
![](http://www.discovery2.co.uk/images/fronthub/hub13.jpg)
Full write up here
![Wink](https://landroverforums.com/forum/images/smilies/Uh2vXQr.png)
http://www.discovery2.co.uk/fronthub.html
Saw you mention doing the 3 amigos and cables next. There is very little if nothing that you can do regarding the 3 amigos. Do your brakes squeak, if you throw a hard panic stop, can you feel the ABS pulsate?
On the ignition wires I have 8mm magnecors on the way from Apex. On the SAI I am thinking I do not (my wires seem to be pretty well accessible compared to how others describe theirs) but I will look again when I get the wire and am back under the hood.
Again Mike thanks for the offer I will take you up on it after I get the wires from Apex. I am in NY they are in PA so I am guessing I will be tackling this on Friday.
The Hubs do fail, well the bearings actually, but they are non-servicable, so you have to replace the whole hub.
![Unhappy](https://landroverforums.com/forum/images/icons/icon9.gif)
The humor is from the designing engineer that finalized the blueprints for this product...After he caught a maintenance man uuuu hittin on his wife.
collin Barrows
08-28-2011 07:13 AM
