02 Disco Shift and Leak
Old Apr 9, 2007 | 11:58 AM
JBRover's Avatar
Default 02 Disco Shift and Leak
Well, finished 30k service with the exception of the transfer case. The e-brake cable was in the way of the fill plug and didn't feel like removing the driveshaft or e-brake to get to it. Anyway, I noticed I had oil leaking from the valve covers and from the oil pan, down to the right side cat. Is this a major problem or can I let it slide for a while? Also, I notice when I drive when it's cold, it hesitates to shift to 4th. It stays in third at 50 mph for 5-6 minutes before shifting. When it gets to normal temp,everything is fine. Problem? BTW, Mike, my drive shaft u-joints are greaseless. Thanks for the help.
Old Apr 9, 2007 | 01:20 PM
Default RE: 02 Disco Shift and Leak
Rover v/c gaskets and engine pan seals are supposed to leak, it gives you some unnecessary to worry about. Unless they are dripping on the ground don't worry.
As for the shifting issue, you need to have someone check the ATF and make sure your tranny is not a little low on fluid. By the way, how long ago was it changed?
Mike
Old Apr 9, 2007 | 02:01 PM
JBRover's Avatar
ChangedATF 2 weeks ago. Had shift issue before that, though.
importdave
Sep 25, 2014 10:18 PM
Phatrowles
Jan 9, 2014 10:36 AM
shonuff93
Mar 28, 2012 09:33 AM
ogden45
Dec 29, 2008 08:29 AM
rgrizzard
Mar 6, 2008 10:16 AM
