02 Discovery doesn't. start after driving.
Old Jun 11, 2013 | 10:17 PM
dr. mordo's Avatar
So before it would start when cold, and now you've replaced the crankshaft position sensor (cps) and it won't start at all?
If so, it's very likely you installed it wrong, which is easy to do.
Old Jun 11, 2013 | 11:38 PM
armink's Avatar
I think I got it right. What could I have done wrong? How to check if it's right?
I'm getting tired of this car. There is always something wrong.
I pulled the old one out and installed the new one the same way back in. When I pulled the old one out there was two long washers that fell out, I assume they were on the bolts that holds the sensor, so I placed them back on the bolts before putting the sensor in. That was the only thing that I was not sure about. Any suggestion is appreciated. Thanks
Old Jun 12, 2013 | 12:35 AM
re: so I placed them back on the bolts before putting the sensor in
Recall that I mentioned :
These parts come off, and must go back on in the exact order they came off
That would be block + sensor + bolts. The extra space you created with new mounting method does not allow the sensor to create the signal that triggers the sparks.
Old Jun 12, 2013 | 02:34 AM
armink's Avatar
Sooo, where did the 1/2" washers came from by taking off the old sensor? They came off wright when I pulled the sensor off of the bolts. I had to undue the two nuts and slide the sensor off of the bolts that are not removable.
Old Jun 12, 2013 | 07:39 AM
Please read this thread https://landroverforums.com/forum/di...nsor%26quot%3B
Old Jun 12, 2013 | 11:45 AM
armink's Avatar
This is the problem. My order was block spacers sensor nuts. I could not see where the spacers came off when I took the old one out. I will reinstall it today, hopefully it will work.
Thank you. Thank you.
Old Jun 12, 2013 | 01:48 PM
armink's Avatar
I got it this time right. After swaping the spacers in the right orderd fired wright up and starts again normal after shutting down.
Thank you sooo much for all you help. I can enjoy the ride again.
Thank you.
Old Jun 12, 2013 | 03:38 PM
Made you smile I bet!
Old Jun 12, 2013 | 04:35 PM
dr. mordo's Avatar
Putting it together wrong is almost as common as the cps failure itself.
Buzz, you don't want to sticky this thread?
Old Jun 12, 2013 | 10:50 PM
armink's Avatar
How do I sticky the thread and what does it do?
