02 sensor question
Old Jul 20, 2022 | 11:27 AM
Richard Gallant's Avatar
Default 02 sensor question
I have a dead O2 (rear) I unplugged the suspect O2 start up the Disco and all sensors are showing readings, both rears flatline at .8.
This seems weird to me any suggestions or more likely explanation of what I am doing wrong ?
Old Jul 21, 2022 | 04:02 PM
matt3502's Avatar
Not to state the obvious, but it sounds like a wiring issue. Do the readings on the rear ones change once the engine gets warm?
Old Jul 21, 2022 | 04:58 PM
@matt3502 An actual drive is the next test, I did notice the engine side connector is damaged but the connection was sound. I was just not sure when the rear O2's started to respond - and you answered my question need to warm the old girl up
Old Jul 22, 2022 | 10:50 PM
@matt3502 thanks for the comment had to pickup some lumber took the Disco and the new O2 start to report the old disconnected one stay at .5 volts. Swapped it out all is good and happy
OgEric
Dec 21, 2018 08:29 PM
mutant
Jul 30, 2017 10:30 AM
adam123
Jan 8, 2011 08:42 PM
Rover Chris
Jun 30, 2009 09:32 AM
discolvr
May 12, 2009 07:09 PM
