02 transfer case linkage snapped
Old Mar 9, 2014 | 04:13 PM
jomandm's Avatar
Default 02 transfer case linkage snapped
I have a 02 discovery with no CDL. I had problems with my transfer case shifter going from neutral back into high and heard a snap and It appears I snapped the linkage just below the shifter. See the photo. I have taken apart the center console and exposed the linkages. Does anyone know of any sources for the new linkage? I have only found it at rover land parts. http://www.roverlandparts.com/1999-2002discoveryiitransfercaseshifter.aspx
Thanks
Josh
Old Mar 9, 2014 | 07:45 PM
OffroadFrance's Avatar
Originally Posted by jomandm
I have a 02 discovery with no CDL. I had problems with my transfer case shifter going from neutral back into high and heard a snap and It appears I snapped the linkage just below the shifter. See the photo. I have taken apart the center console and exposed the linkages. Does anyone know of any sources for the new linkage? I have only found it at rover land parts. 1999-2002 Discovery II Transfer Case Shifter
Thanks
Josh
I think your best bet is a Landrover wreckers yard. They seem as rare as hen's teeth on Eblag.
Check the way you are changing the low/high level box. It should move easily provided you are rolling less at than 5 mph and with the autobox in neutral. Don't force the lever or it will break every time.
Old Mar 9, 2014 | 08:34 PM
ralphobell's Avatar
Which piece snapped? I have the part shown in the attached photo. Most anyone would that has done the cdl conversion if they removed it.
Old Mar 9, 2014 | 10:39 PM
zeroone's Avatar
Are you sure you didn't snap the cable? I did. The lever on the xfer case was seized. Apparently it had never been put in low range. Going caveman on the small shifter is never a good idea.
Old Mar 10, 2014 | 06:18 AM
jomandm's Avatar
I did try rolling in neutral below 5 mph but it still did not budge. Yes it was the cable that snapped and not the bracket. See attached photo.
Old Mar 10, 2014 | 06:24 AM
zeroone's Avatar
If I remember my buddy said that cable was 170 his cost at the dealer he works at. He pays 10 over cost. So.. $300?...lol
Old Mar 10, 2014 | 07:22 PM
jomandm's Avatar
I called Paul grant today and got one from for a good price.
Old Mar 10, 2014 | 07:45 PM
zeroone's Avatar
whats a good price? fixing that cable is on the "summer" repair list along with the sunroofs, headliner, and interior leaks.
Old Mar 11, 2014 | 06:01 AM
jomandm's Avatar
$35 including shipping and should arrive today.
Old Mar 11, 2014 | 06:02 AM
zeroone's Avatar
Awesome thanks.
fpdavis3
Jun 9, 2014 09:00 AM
pgoodrich
Jan 1, 2014 07:24 AM
blondebunny
Jan 28, 2011 03:58 PM
hilltoppersx
May 17, 2010 08:51 PM
cowtown
Dec 15, 2009 10:25 PM
