03-04 head light disassembly
Old Jan 5, 2021 | 09:58 AM
keninnc's Avatar
Default 03-04 head light disassembly
Has anyone disassembled a 2003-2004 headlight with some knowledge of what to do and more importantly what NOT do do.
I have some condensation in one. I put a small bead of silicone around the clear edge a few months back. But obviously that did not work.
Thanks,
Old Jan 5, 2021 | 10:05 AM
whowa004's Avatar
Take your time and it's pretty simple, lots of little tabs to be careful with. Thread below touches somewhat on how to disassemble and what I used when I pulled mine apart.
https://landroverforums.com/forum/ap...etrofit-65454/
Old Jan 5, 2021 | 10:34 AM
ahab's Avatar
I had a consistent moisture problem on the driver's side light in my first truck and had excellent results by removing the bulbs and using a heatgun (hairdryer will work) to dry all the moisture in the assembly and then filling this groove all the way around the headlight with 2 part clear epoxy, using a toothpick as an applicator. Two years on and it was still dry.
Old Jan 5, 2021 | 02:07 PM
Sean Maginness's Avatar
Thanking you for posting that link. I have a spare set of 03/04 headlights that I'm planning to put projectors in. I've done this before on a different car, but always great to see how someone else has done the same thing. I put a set of LED bulbs in and the light output is been good enough to reduce my itch for projectors but now I'm getting the itch again
Old Jan 5, 2021 | 06:13 PM
Extinct's Avatar
Put the light on the windshield , back end up, take the rear cover off. The heat from the sun will dry it. Seal it with silicone on all the cracks. Get one of those dessicant packs, cut it open, put the beads in the bottom of the light. The heat from the light will regenerate the dessicant every time it is used.
Eurobahn LandRover
Detailing
Jan 18, 2016 04:00 PM
drowssap
Oct 30, 2015 09:25 AM
wick_60010
Jun 28, 2011 02:58 PM
clemsrover
Apr 22, 2011 08:00 AM
KC771
Jul 27, 2006 10:29 PM
