03-04 Headlight Conversion DONE
Old Nov 18, 2008 | 05:27 AM
99TEXASD2's Avatar
Default RE: 03-04 Headlight Conversion DONE
as far as the brackets are concerned you basically need to be able to extend the framing on top out so that you can cut slots in it for bolts to go through and screw into the brass mounting holes on the headlights. we could have made it a lotnicerwith metal sheeting to work with but use what ya got...the biggest thing with the whole project was measure 3 times cut less than you measured...test fit repeat above steps till eventually you have it right. Tools REQUIRED: Dremel with LOTS of cut off wheels (or Air powered cut off tool with several extra wheels.) Pop Rivet gun, permanent marker for marking where to cut, DRILL and several bits. Socket set, screw drivers etc...
Old Nov 18, 2008 | 02:28 PM
sdsilvere38's Avatar
Looks good! Are you selling your old headlights? I need a drivers side.
Old Nov 18, 2008 | 04:54 PM
Street Wolf's Avatar
Probably so, give me a couple of days and I'll let you know for sure.
Old Nov 19, 2008 | 06:39 PM
Sounds good. Just PM me.
Old Nov 19, 2008 | 10:00 PM
Will do.[8D]
Old Nov 19, 2008 | 10:19 PM
AK Rover's Avatar
Where did you get your HID light kit? I am going to stick with my stock lights but want to upgrade to HID.
Old Nov 19, 2008 | 10:24 PM
Switzer's Avatar
[sm=smiley20.gif]
Cheers,
Pete
Old Nov 19, 2008 | 10:31 PM
ORIGINAL: AK Rover
Right here AK-
http://myworld.ebay.com/hidwholesale88/
Very good stuff, had it about a year now, covered it in mud, water, ice, 110+ heat, even submerged the light bulbs themselves in water before.
Old Nov 21, 2008 | 05:34 AM
99TEXASD2's Avatar
^^^he forgot to mention we also had the ballasts submerged in water as well as the bulbs...headlights actually filled with water. and those bulbs never missed a beat
glassman66
Jul 17, 2012 08:31 AM
GamecockRover
Jul 16, 2012 02:00 PM
kfx4001442
May 18, 2008 09:50 PM
m1943
Mar 11, 2008 12:04 PM
Stickestar
Appearance & Camping Set Ups
Dec 13, 2006 03:25 AM
