03/04 oil cooler
Old Apr 22, 2015 | 06:08 AM
abran's Avatar
Default 03/04 oil cooler
Added an 03/04 trans cooler as an oil cooler. The trans coolers on the 03/04s are the biggest coolers on the D2s.
I used a set of lines from an 02', removed the blank off plugs on the front cover. Fits perfectly on the radiator.
Old Apr 22, 2015 | 07:50 AM
DustyLBottoms's Avatar
Excellent, this is one of the best upgrades you can do. Incidentally, you might want to put fresh o-rings in the quick disconnect on the cooler lines. Each line take TWO o-rings stacked on top of each other. See my thread here: https://landroverforums.com/forum/di...-o-ring-72375/
Old Apr 22, 2015 | 08:14 AM
drowssap's Avatar
4.6 coolers are large than 4.0's same with the tranny coolers
Old Apr 22, 2015 | 08:16 AM
abran's Avatar
4.6's don't have oil coolers, only one trans cooler. That is why I added a 4.6 trans cooler as an oil cooler.
Old Apr 22, 2015 | 08:17 AM
abran's Avatar
Got the info from your thread, changed them all. Thanks!
Old Apr 22, 2015 | 08:19 AM
drowssap's Avatar
4.6 range rover
Old Apr 22, 2015 | 08:24 AM
abran's Avatar
Originally Posted by drowssap
4.6 range rover
^true, I looked into using the P38 one but it has screw on fittings, plus it's not quite as large as the 04' trans cooler.
Rufflyer
Mar 22, 2015 10:13 AM
Beaulim
May 2, 2014 08:03 PM
wheelgarage
Dec 29, 2012 01:50 PM
javven
Jul 15, 2012 10:09 AM
