03/04 SLABS for CDL in a 2001
Old Nov 18, 2022 | 08:18 PM
nashvegas's Avatar
If you have an "SLS" SLABS in a non SLS truck, you will get an SLS warning light on the dash if you don't have the system installed I believe... right? (that's how you'd know if it was an air suspension enabled SLABS box)
Old Nov 26, 2022 | 05:56 PM
JoshD's Avatar
Okay, I unplugged the old SLABS unit and plugged in the 03 unit and it seems like everything functions as it should and no more CDL lights after a restart. For now its, just dangling by the wire harnesses. Anyone know of a good write up for the actual removal process? It looks to be a bear and I don't want to pull anything out I don't have to. Thanks
Old Nov 26, 2022 | 07:33 PM
Best4x4's Avatar
There is a 14mm nut you remove, and then the bracket can be taken down and give you access
Old Nov 27, 2022 | 07:51 AM
mln01's Avatar
The procedure is detailed in the RAVE (starting on p.900 of the PDF I have). You first remove the BCU after removing the glove box. That gives access to a nut waaay back in there that you remove to remove the bracket holding the SLABS box. I've done it three times, most recently just a couple weeks ago. Not difficult, just tedious.
If you don't have a copy of the RAVE you can download it from the link in my signature below.
Old Nov 27, 2022 | 05:38 PM
JoshD's Avatar
Thank you for the replies. I only had to remove the glovebox door and the underdash cover. Apparently the SLABS had been changed out before and the person was kind enough to not put that very back nut on the bracket so it was just a matter of getting the bottom 2 and the front top off which was easy. I didn't have to remove the BCU or anything else.
rikkd
Sep 29, 2021 04:24 PM
Jeff Blake
Sep 1, 2017 12:16 PM
Luckyjayb
Jun 17, 2017 03:28 PM
mln01
Apr 27, 2015 09:01 AM
Disco Alan
Jul 11, 2006 06:33 PM
