03 CDL wiring
Old Apr 11, 2021 | 04:43 PM
Shiftonthefly1's Avatar
I read that too. I reused the aluminum washer it had on it. I'll mess w that before I move forward.
Thanks so so much for the simplified direction.
Old Apr 11, 2021 | 06:20 PM
ahab's Avatar
You need continuous ground. Those switches are known to be flaky, (at least at my house....) possibly due to lack of use, but to add insult to injury they're like $50 a pop. I put in a manual switch in mine using some spare dash switches because I don't trust them and they're too much of a PITA to swap out. Same principle, feeding ground to the SLABS ECU, but using a manual switch instead of the pin switches in the TC. Not for everyone but it works for me.
Old Apr 12, 2021 | 06:33 AM
mollusc's Avatar
A continuous ground would cause the light to be on all the time. All the CDL switch does is connect the signal wire to ground. You can do that manually, or you can do it with the switch on the t-case.
Old Apr 12, 2021 | 07:01 AM
ahab's Avatar
Sorry, poor grammar on my part. You need a continuous ground whenever the TC is locked, as opposed to a brief indication of a connection. In order for HDC to function the ground signal needs to be present on Pin 7 of C0668. When the TC is unlocked then the ground signal to SLABS should go away.
Old Apr 12, 2021 | 07:48 AM
That button is a fantastic idea. Thank you. If I can't sort this out that's what I'm going to do.
Oasisplayer311
Jul 1, 2024 07:25 PM
craiglud
May 4, 2020 01:02 PM
Mark G
Oct 7, 2015 06:43 AM
ajh
Aug 26, 2007 06:40 PM
Disco Alan
Jul 11, 2006 06:33 PM
