'03 D2 Coolant Flush - tonight
Just make sure you can touch the lower radiator hose with your hand and hold it thgere for a min or so.
If you drain all the coolant out of a hot engine you run the risk of cracking the block.
Same thing if you add cold water to a hot engine, either by washing it or refilling the cooling system.
It does not need to be stone cold, just cool.
A hour of cooling off time is all that is needed, less if it is cold out side.
15-20 min is plenty, a hour is overkill, the water can still be warm just not hot.
wannabe
Jan 24, 2011 10:42 AM
tunernewb92
Jun 23, 2009 04:44 PM
Bishop
Feb 25, 2008 07:40 PM
