'03 in the death VIN range made a quiet knocking sound...
Old Dec 28, 2014 | 05:56 PM
Alex_M's Avatar
Originally Posted by acg
Get the water pump with the improved brass impeller.
Any specific big reasons that will matter for the next ~40k miles? I'm starting my second semester of college and money is tight.
Old Dec 29, 2014 | 02:54 AM
acg's Avatar
acg
I suggested the brass impeller as brass has better corrosion resistance. The standard iron impeller version will work as well. Most water pumps fails due to the bearings and not the impeller. You should be okay if money is tight.
Old Dec 29, 2014 | 06:52 AM
Alex_M's Avatar
Awesome, I'll stick with iron till I'm out of school then. Thanks!
Old Dec 29, 2014 | 10:38 AM
Dave03S's Avatar
For future readers of this thread, the '03 Vin "death range" had nothing to do with the OP's issue and tends to still be drug up from the depths when owners panic.
For the record the issue involved misplaced dowel pins holding the front cover to the block. This led to lateral stress being put on the oil pump gears which caused them to break prematurely leading to low oil pressure which leads to a loud ticking. Most actual issues of the front cover being misaligned have been resolved long ago. The factory remedy was to completely replace the block. I got a new block this way at 38k. No truck with a compromised oil pump will still be on the road with 130k on the clock.
Not every loud ticking is a broken oil pump.
Oil pumps break on all years, not just the '03.
Low oil pressure happens for other reasons.
Ticking happens for other reasons.
High temps happen for other reasons besides low oil pressure... Like the cooling system... which is more known to fail when not maintained than the oil pump.
Old Dec 29, 2014 | 12:09 PM
Alex_M's Avatar
Thanks for clearing all that up for other readers, though I should note that I haven't had any problems with high temps.
Old Dec 29, 2014 | 12:11 PM
dusty1's Avatar
so it was another victim of '03 vin number death range. good to know.
i'm joking. glad you sorted it out.
mowensmd
Aug 21, 2024 11:07 AM
aarongregor
Nov 21, 2012 04:08 PM
2K Disco II
Nov 4, 2011 01:58 PM
Rover Chris
Apr 23, 2009 05:03 PM
MichiganJim
Nov 30, 2007 07:42 PM
