03 DII - P1451 - Evap. Leak Detection Pump?
Old Aug 9, 2020 | 06:20 PM
neuropathy's Avatar
Default 03 DII - P1451 - Evap. Leak Detection Pump?
Hi everyone,
I've got a P1451 code and I've read that it could be the evap. leak detection pump or something related to it. I tried to take off the gas cap and tighten it again - I'll try cleaning it a bit with the business-end of a yellow/green sponge as recommended.
I'm wondering about a few things though: I understand the pump is located on the passenger side by the rear drive shaft, but I'm wondering if I need to remove anything else to get to it?
Also, in checking the electrical harness connection, I can try to pull the connector off and brush it a bit then put it back on, but should I try to clean it with anything like contact cleaner or put in some dielectric grease? I'll try to check out the wiring itself too and see if mickey mouse or chucky cheese got in there.
If I have to replace the pump, there wouldn't be any hoses with liquid connected to it, right? Also, I wouldn't know if I've got the 3 or 4 prong version of this pump and which one this is, but it appears the Bosch part is the 4-pin type and this is likely what's on my 2003 DII
This is the pump I'm considering:
Amazon Amazon
Old Oct 17, 2020 | 06:15 PM
neuropathy's Avatar
Does anyone know anything about this? The code returned a bit after being cleared. I haven’t installed the new part linked above yet. I wasn’t sure if that was the best course to take here.
Old Oct 18, 2020 | 02:26 AM
Brandon318's Avatar
Very coincidentally, I just posted about this leaking. There’s definitely some fluid in the hoses, just no idea where it’s coming from. Also, no codes for me. Interested to see where this goes.
Kevin Chambers
LR2
Jan 14, 2020 02:16 PM
zuke
Nov 20, 2019 11:04 PM
cappedup
Jan 7, 2018 09:11 PM
101ABN
Apr 2, 2012 08:05 PM
antichrist
Apr 26, 2011 02:00 PM
