'03 DII shift lock solenoid
Old Aug 3, 2012 | 06:48 PM
A5scott's Avatar
Default '03 DII shift lock solenoid
so I finally got stuck in park... thanks Chris for help on the phone...
I got the shifter **** off, and can push the plunger in to shift perfectly. Brake lights do not work.
Do I need to replace the solenoid along with the brake switch? Do I need to loosen the three 10mm bolts to get the solenoid out?
is this the brake switch I need to fix it?
Import Direct 18-1841 - Stoplight Switch | O'Reilly Auto Parts
thanks!
Old Aug 3, 2012 | 07:13 PM
A5scott's Avatar
ok, so i reached up behind that black plastic cover under the dash, up by the pedal, and the brake switch popped out in my hand... I unplugged it from the wires and here it is.
so, i didn't see the orientation of the switch, but how do I pop that plastic cover off to see where the switch goes? it has 2 round discs where it attaches. I tried to get a flat screwdriver behind it but didn't do much. or do most pop it back in blindly without removing the plastic cover
Old Aug 4, 2012 | 04:31 PM
00&04 Disco's Avatar
Default Fix
Directly behind the brake pedal there is a plate that has an oblong hole in it that will fit the side of the switch with the plunger on it through it. Push it through so it goes through the hole and then turn it and it will lock in place. If you lay on the floorboard it is easier to see the hole. You might have to take the plastic cover off that covers some of the wires and such under the access cover beneath stealing wheel to see it better. This should fix both the brake light problem and the shifting problem. Good luck!
Old Aug 4, 2012 | 04:51 PM
A5scott's Avatar
thanks... totally fixed! i was able to get up there without removing the plastic shield. i got a mirror and could see the shape of the slot, inserted new switch and rotated 90 degrees, and got it working. shifting and brake lights work
thanks
remac
Mar 14, 2014 08:31 AM
far4cges
Aug 6, 2012 08:25 PM
Dan Wallace
Jul 30, 2012 03:51 PM
twaszak
Jun 27, 2011 01:32 PM
jared
Dec 20, 2007 06:51 AM
