03 disco 2 no crank no spark
Old 12-12-2021 | 01:44 PM
The Deputy's Avatar
You have to be cranking engine over to get fuel pump to run, that's why crank sensor signal is necessary. The crank sensor sends a signal to ECM, ECM sends signal to fuel pump relay (ground circuit) which activates pump and coil packs and injectors.
  #22
Old 12-12-2021 | 01:48 PM
Gracewyattdad's Avatar
I'm getting 0.15 volts from CKP to ECU while cranking. Sound correct?
  #23
Old 12-12-2021 | 08:17 PM
Extinct's Avatar
its not an analog signal, its a digital signal. The sensor registers the notches on the flywheel as they go past. There is a specific pattern of pulses the computer looks for. You would need an osciilliscope or a high end scanner to read it. If it is working correctly the fuel injectors will pulse when cranking. If you want to test you can pull the injectors and watch them for squirts.
  #24
Old 12-13-2021 | 02:11 AM
The Deputy's Avatar
Crank sensor basically looks for two things, engine rotation and number one cylinder...and passes on the infomation to ECM.
This may help...
  #25
Old 12-13-2021 | 04:07 PM
tydenioluwa's Avatar
Originally Posted by Gracewyattdad
2003 disco 2. New fuel pump, new ckp. No fuel, no spark. Help
Does it turn over ?
فلل للبيع في اسطنبول
  #26
Old 12-13-2021 | 04:09 PM
Turns over, no crank
  #27
Old 12-13-2021 | 05:43 PM
The Deputy's Avatar
Turning over and cranking are the same thing...battery/starter motor does this.
Your rover is cranking over...but not starting. Need fuel, compression, spark and timing to achieve this.
Gracewyattdad
12-09-2021 02:14 PM
aemnky606
01-17-2016 01:46 PM
GROVERDISCO
12-14-2012 01:54 PM
byrona8
03-16-2010 10:09 PM
NWDisco
12-13-2006 03:11 AM
Quick Reply: 03 disco 2 no crank no spark
