03 disco 2 no crank no spark
Old Dec 12, 2021 | 01:44 PM
  #21
The Deputy's Avatar
You have to be cranking engine over to get fuel pump to run, that's why crank sensor signal is necessary. The crank sensor sends a signal to ECM, ECM sends signal to fuel pump relay (ground circuit) which activates pump and coil packs and injectors.
Old Dec 12, 2021 | 01:48 PM
  #22
Gracewyattdad's Avatar
I'm getting 0.15 volts from CKP to ECU while cranking. Sound correct?
Old Dec 12, 2021 | 08:17 PM
  #23
Extinct's Avatar
its not an analog signal, its a digital signal. The sensor registers the notches on the flywheel as they go past. There is a specific pattern of pulses the computer looks for. You would need an osciilliscope or a high end scanner to read it. If it is working correctly the fuel injectors will pulse when cranking. If you want to test you can pull the injectors and watch them for squirts.
Old Dec 13, 2021 | 02:11 AM
  #24
The Deputy's Avatar
Crank sensor basically looks for two things, engine rotation and number one cylinder...and passes on the infomation to ECM.
This may help...
Old Dec 13, 2021 | 04:07 PM
  #25
tydenioluwa's Avatar
Originally Posted by Gracewyattdad
2003 disco 2. New fuel pump, new ckp. No fuel, no spark. Help
Does it turn over ?
فلل للبيع في اسطنبول
Old Dec 13, 2021 | 04:09 PM
  #26
Turns over, no crank
Old Dec 13, 2021 | 05:43 PM
  #27
The Deputy's Avatar
Turning over and cranking are the same thing...battery/starter motor does this.
Your rover is cranking over...but not starting. Need fuel, compression, spark and timing to achieve this.
Gracewyattdad
Dec 9, 2021 02:14 PM
aemnky606
Jan 17, 2016 01:46 PM
GROVERDISCO
Dec 14, 2012 01:54 PM
byrona8
Mar 16, 2010 10:09 PM
NWDisco
Dec 13, 2006 03:11 AM
