03 disco brakes, rotor locator screw
Old Jun 16, 2012 | 11:45 AM
A5scott's Avatar
Default 03 disco brakes, rotor locator screw
Hi,
so I was trying to replace rotors and pads on all 4... looks like the rover dealer that did the brake job last time re used the same stripped locator screw on the rotor, and I also stripped it some more. any ideas on the best way to get it out? Drill it out?
also, what size is the screw?
thanks
scott
Old Jun 16, 2012 | 12:40 PM
Drill it out, do NOT replace it as it is NOT needed, its ONLY job is to hold the rotors on the truck as it rides down the assembly line with no wheels on it.
The wheels hold the rotor in place.
Any car I have ever done brakes on that has one I trow it away.
It is a #2 Phillips if I remember right.
Old Jun 16, 2012 | 12:56 PM
A5scott's Avatar
thanks... yeah that screw is kind of small to be an important part.
thank you
scott
Old Jun 16, 2012 | 01:01 PM
Bkreutz's Avatar
A manual impact driver works well in removing that screw, here's a link to one example but all of the tool companies make them Great Neck/4 Bits Impact Driver Set (IMD5) | Impact Driver Set | AutoZone.com
Old Jun 16, 2012 | 04:44 PM
drowssap's Avatar
X2 on the impact.
X2 its ONLY job is to hold the rotors on the truck as it rides down the assembly line
Old Jun 16, 2012 | 04:52 PM
Remove it and do replace it, by the way, it has a #4 head on it.
Old Jun 17, 2012 | 05:59 PM
A5scott's Avatar
ok thanks again guys
scott
bballjames
Sep 8, 2012 07:59 PM
NJ_LR3
Apr 2, 2012 06:10 AM
94svt50
Dec 28, 2011 08:41 AM
lipadj46
Aug 17, 2009 10:08 AM
lipadj46
May 31, 2009 05:44 PM
