'03 Disco Headliner/leather cleaner
Old Apr 14, 2007 | 08:46 PM
bigugly82's Avatar
Default '03 Disco Headliner/leather cleaner
I've checked Rovers North and Atlantic British's websites and can't find one. Anyone know where (other than the dealer) I can pick one up? I left the sunroofs open last night during a down pour. There was also a purple piece of paper on the pass. front seat, which bled. Any good leather cleaners?
-ugly
Old Apr 14, 2007 | 09:25 PM
Default RE: '03 Disco Headliner/leather cleaner
The purple will be hard to pull out of the leather, don't use anything till you go talk to a good shoe repair shop, they are real familiar with stains on leather. the rest of the time use some Lexol saddle soap and a day later some Lexol conditioner and your seats will look and feel like new for along time.
Mike
Old Apr 14, 2007 | 09:27 PM
rphotographer's Avatar
I have ssen headliners on EBAY.
Ralph
Old Apr 14, 2007 | 11:14 PM
Have you tried to dry out your headliner and then clean it? The dealer is the only one that can order you a new one and they are way expensive. Some auto shops can reline an old one but not always with the best results.
Mike
Old Apr 15, 2007 | 10:57 PM
bigugly82's Avatar
to be honest with you, I wondering how hard I can scrub it before I damage it (the headliner). Are they pretty rugged?
-good call on the leather Mike.
Old Apr 16, 2007 | 10:51 AM
Describe the stain on the headliner and is it sagging?
The one thing you don't want to do is use the wrong cleaner and scrub the stain deeper into the headliner material.
Mike
Old Apr 16, 2007 | 04:35 PM
bigugly82's Avatar
There is a slight sag near the passanger side sun visor where it attaches to the roof. The stain looks like a "sweat ring" on the outside of a baseball cap. I was thinking of using a sponge to try to clean it. Any advice on a cleaning solution?
thanks
Old Apr 16, 2007 | 07:29 PM
I would suggest drying it out by using a shop vack with a small flat nozel, see if you can suck out the moisture.
As for cleaning it, some sort of a very mild soapy solution sprayed on just one spot, then again the shop vac to remove the soapy solution then spray just a small amount of water to rinse it off. Let it dry and see how it turns out before you try and clean the whole area.
Mike
Old Apr 16, 2007 | 11:55 PM
okdiscoguy's Avatar
Be sure to use a mild soap. The cleaner can cause the foam backing to separate from the cloth, and the whole thing will be sagging. A friend in high school sprayed his suburban with interior cleaner, and the next morning, be had a clean headliner on his head.
Not sure if your backer is messed up, or not, but an upholstery shop should be able to re-line it for around $300. I have a buddy that does upholstery, and headliners can be done right. Just like new.
Good Luck
jamestfl
Feb 5, 2014 06:37 PM
SuperiorCarCare
Detailing
Nov 26, 2013 12:46 PM
targotsi
Jan 31, 2009 06:12 PM
Young
Jun 29, 2008 02:48 PM
