'03 Disco intermittent stutter/stalling ???
Old Aug 4, 2011 | 09:54 PM
disc oh no's Avatar
Default '03 Disco intermittent stutter/stalling ???
Hey guys, I have a slight problem with my '03 Disco. For a couple months it sometimes hesitates slightly usually when just slightly pressing on the accelerator. No "Change Engine Light" (yet) I have changed the throttle pos. sensor recently but still does this... sometimes a lot (over and over while driving along at a constant speed). Sometimes it doesn't do it for weeks. Then just today it stalled when I was slowing down to stop at a stop sign. It started right back up and ran fine but, don't want my wife stuck somewhere while I'm at work or something. I was thinking maybe the crankshaft position sensor??? Fuel pump???
Tell me what you think. Thanks in advance for your time and any help you can give.
Old Aug 4, 2011 | 10:14 PM
IMHO you would be wise to check fuel pressure, usually there is a Schrader valve on the fuel rail for this purpose. RAVE gives you accepted PSI range, believe it is somewhere between 32 - 36 PSI. Restricted fuel filter, fuel pressure regulator, or fuel pump can all impact fuel pressure. Also, might be a good time to clean the throttle body and MAF with correct type of solvent, rated for the purpose and OK for CATs.
Old Aug 4, 2011 | 10:23 PM
disc oh no's Avatar
Good idea, I'll check the fuel pressure asap. I don't have a fuel filter but probably have all the other stuff, right??
Old Aug 4, 2011 | 10:34 PM
disc oh no's Avatar
Well, sorta have filters on the bottom of the fuel pump I guess, (screens or whatever). No external or "easy to replace" filter though.
Old Aug 5, 2011 | 04:21 AM
On D1's it is a little can in-line filter, over the right rear tire. But you just have a sock in the tank.
dregill
Aug 5, 2015 07:27 AM
resiroper
May 1, 2013 08:50 AM
Chris Miller
Jan 10, 2013 07:50 PM
mark wilson
Sep 20, 2011 05:54 PM
bgarvertn
May 15, 2010 11:48 AM
