Sponsored by: CARiD
Help!! Intermittent stalling..
Old May 15, 2010 | 05:43 AM
bgarvertn's Avatar
Default Help!! Intermittent stalling..
Good morning. I am confident a member has insight into a little problem I am having. My wife's '03 Disco II (79K) has begun to randomly die while driving, with no erratic operating conditions prior to failure. To add insult to injury, the automobile will not restart, (but WILL crank healthily), and after a period of time, say 5-60 mins, will restart and operate normally. Typically, 3-5 miles of driving is all the auto will do. I have replaced Air idle control valve, and am at the end of the Noose!?! One side note, approx 2 weeks prior to problem developing wife tried to run vehicle on air, not gas!! Any sage words of wisdom would be greatly appreciated...
Old May 15, 2010 | 07:23 AM
d2luvr's Avatar
That sounds like the crank position sensor. 2 bolts one plug, 10 minute fix.
On another note, does she know that running it out of fuel will drastically shorten the life of the fuel pump?
Old May 15, 2010 | 07:27 AM
Yes, it is the crank sensor which is kind of common and fairly inexpensive to replace, about $65 in parts and a hours or so labor depending on who is doing it.
Old May 15, 2010 | 11:48 AM
bgarvertn's Avatar
I sure appreciate the info... I have had a lengthy discussion w/ wifey how it is not ideal to run out of gas!! Will try Crank position sensor..
Chris Miller
Jan 10, 2013 07:50 PM
disc oh no
Aug 5, 2011 04:21 AM
DISCOVERY182
May 12, 2009 11:40 AM
Rover5150
Nov 28, 2007 09:57 AM
MikeRover
Jun 25, 2005 04:34 PM
