03 disco mifire 43k on vehicle
Old Dec 28, 2008 | 09:07 PM
mx930's Avatar
4wd High
Default 03 disco mifire 43k on vehicle
My girls 03 disco has 43k on it. SHe told me about a week ago it seemed to be running rough. I didn't think much of it untill I got in it the other day. Service engine lightis blinking, and misfiring terrible.
Codes
P0304
P0306
po307
P01300
I am going to order some Magnacor 8mm and Bosch plus 4. WHat other dmaged do you think could have been done since the vehicle was driven over a week like this.I am hoping none but I am guessing possibly theO2 sensors areno longer good. Should I be looking into some coil packs as well?
Old Dec 28, 2008 | 09:12 PM
Default RE: 03 disco mifire 43k on vehicle
Just the plugs and wires.
Then clear the codes and drive it and see what, if any, come back.
No you do not need to buy coils.
Old Dec 28, 2008 | 09:15 PM
mx930's Avatar
4wd High
Thanks!Would an additional code read if the coil packs are damaged?
Old Dec 28, 2008 | 09:21 PM
As far as I know, no, no codes for bad coil packs.
Old Dec 28, 2008 | 11:19 PM
AK Rover's Avatar
A blinking service engine light means serious trouble and the vehicle should not be driven until the problem is fixed. You could do more damage.
Old Dec 29, 2008 | 08:30 AM
ORIGINAL: mx930
Thanks! Would an additional code read if the coil packs are damaged?
Yes, there are 12 fault codes running from P0350 to P0362 indicating different coil issues.
You are doing the right thing with the wires and plugs. What octane gas does she run in her Disco?
When you get it back up and running, you might consider doing an induction clean to help de-carbon the engine for better performance.
Old Dec 29, 2008 | 06:32 PM
mx930's Avatar
4wd High
Sounds good. I have my Magnacor 8mm an Plus 4's on order they should be here wed. She has run 87 but that will no longer happen. I will let you know how I make out. Thanks for all the info and help.
ssssnake529
Aug 11, 2021 01:29 AM
vrracr
Sep 7, 2011 05:20 PM
blast20
Feb 14, 2010 04:49 PM
ajordan_0012000
Feb 20, 2009 02:19 PM
dma3
Jan 6, 2006 01:08 AM
