03 discovery 2 backfiring
Old Nov 8, 2010 | 01:37 PM
David Simmonds's Avatar
Default 03 discovery 2 backfiring
iv got an 03' discovery 2 92,000 miles on it. im getting a cylinder 8 misfire and its backfiring into the intake. any thoughts ? also. what should the compression be on the cylinders ?
Old Nov 8, 2010 | 09:40 PM
mwindth's Avatar
Premium gas only, a tune-up with new plugs and 8mm wires for starters...for compression, check here: http://www.landroverresource.com/ and type "compression" in search block.
Old Nov 8, 2010 | 09:52 PM
ok. but how can we explain the backfiring into the intake ?
Old Nov 8, 2010 | 10:06 PM
mwindth's Avatar
I would guess sticking or burnt valves...you are on the right track with a compression test (check compression when the engine is warmed up)...you might need your heads rebuilt.
Old Nov 8, 2010 | 10:37 PM
i cant find it. i check cylinder 1 and 8 they were both between 60 - 70 psi... :/
Old Jul 23, 2014 | 04:59 PM
josh39520's Avatar
3rd Gear
Default did you ever
Did you ever find out what was wrong with the engine
rvrchk320
Nov 30, 2007 07:53 AM
craiglevy
Sep 17, 2007 09:35 AM
slbrous
Mar 15, 2007 03:35 PM
Raytelman
Aug 5, 2005 03:59 PM
Raytelman
Jul 27, 2005 10:44 PM
