'03 Discovery -Blinking CEL light help!!!!....
Old Sep 6, 2010 | 06:07 PM
Dan87GT's Avatar
Default '03 Discovery -Blinking CEL light help!!!!....
Hello....looking for some advice on my '03 SE7 with 93k....I developed a miss and rough idle and triggered code P1300 and misfires on Cyl. #1 and #5..I was on a long trip and I started to get a blinking CEL going uphill....but the engine never overheated......it did have the original wires..I was loosing coolant and oil....
I changed the wires, plugs, and replaced the gaskets from the lower intake manifold up...I found a coolant leak at the lower intake gasket...and the oil loss was from loose valve covers....
After I fired her back up she ran great...but I get P0300 and P0301 codes and it idles very rough...also, at ~ 1,250 RPM the CEL blinks until I give it a little gas and the light goes out....usually comes on going up any type of uphill grade and sometimes right at start-up........I triple checked the wires, I am not loosing coolant, and no coolant in Cyl. # 1......I was doing a bunch of searches and I see MAF's could cause this...any thoughts..thank you!!!.....Dan
Old Sep 6, 2010 | 06:10 PM
hilltoppersx's Avatar
what are the exact codes you are getting now?
Old Sep 6, 2010 | 07:24 PM
Dan87GT's Avatar
This weekend I cleaned the Bank 1, Sensor 1 O2 connector as it was covered in oil from my valve covers....I cleared the codes.....so after ~ 3 days of driving I have a P0301(cyl. 1 misfire) and a P0135(o2 heater circuit, Bank 1, Sensor 1)...and a blinking CEL a few times....Also, I changed all the O2 sensors ~ 65k.....thank you!...
Old Sep 7, 2010 | 01:31 AM
bosshogt's Avatar
I too replaced my O2 sensors at 68K. You might try pulling the two front O2's and cleaning the carbon off them. I replaced the front right O2 again at 88k and it cured my bad idle. Cleaning them is free and they could be foweled up since it has been running rich/lean. I have not found a good answer for testing a bad ignition coil or MAF. Other than if it throw the MAF code.
Old Oct 7, 2010 | 11:23 AM
Dan87GT's Avatar
Update after being out of town for a few weeks.....I replaced the front O2 sensors again to see if this would solve the problem.....very quickly I get the P0301 Cyl. 1 misfire code again...and the CEL still blinks at low RPM......I am at a loss.....any help would be greatly appreciated!!!!...thanks Dan..
Old Nov 4, 2010 | 06:39 PM
Dan87GT's Avatar
Update to the update....not sure what else to do....so...I installed a new MAF, LR model....still idles rough and the blinking CEL is on.....only code is a Cyl 1 misfire....any thoughts at all?.....I read some other posts about switching wires to see if it was the cyl or wires/coil....which one would I swap with #1?...
thank you!!...
P.S. For sale - used MAF Sensor...tested good..
Old Nov 5, 2010 | 09:10 AM
have you done your head gaskets? from the pic it looks like you are losing coolant.
Old Nov 5, 2010 | 09:13 AM
Send me your tele number and I'll walk you thru what to do.
hankeester
Jan 2, 2014 12:53 PM
DeepBlueWater
Oct 15, 2007 07:38 PM
shearer60
Oct 15, 2007 12:50 PM
disco1
Jun 5, 2007 10:02 AM
Rovercountry
Dec 25, 2005 09:42 AM
