03 Discovery wont run!
Old Dec 16, 2007 | 10:27 AM
logoes.biz's Avatar
Default 03 Discovery wont run!
2003 autotransmissiondiscovery,
I drove down the road, i stopped and then turned a corner, I hearda pop.
The auto transmissionwont work. the engine runs fine, but it wont move.
I had to tow the car. The car wont go into any gear, just acts like its in neutral.
the car only has 35,000 miles.
Any ideas?
Old Dec 16, 2007 | 11:12 AM
Default RE: 03 Discovery wont run!
Are you still in warranty??
You have broken either one of your diffs/axles, be it the front or the rear I can't tell you with out looking. What sort of a shop did you tow it to, dealer or small shop?
If you are out of warranty, I hope not the dealer cause they will kill you with this repair where in a small non dealer shop, you can install a used diff or axles and save a bundle.
Old Dec 16, 2007 | 12:35 PM
logoes.biz's Avatar
small shop.. and yea i think i am.
Old Dec 16, 2007 | 02:22 PM
That is not the answer I was looking for, either you are or are not in warranty, if so is it a factory warranty or aftermarket, if aftermarket does it cover axles and diffs?
Come on, you must have a copy of some warranty, what is it?
Old Dec 18, 2007 | 03:12 PM
khandrh's Avatar
The same thing accurred to me back in July. It turned out to be the front differential. The repair is expensive. With luck, I had purchased an extended warranty and it was covered.
m3dragon
Feb 24, 2015 10:08 AM
lakebluemickey
Sep 1, 2012 11:51 AM
wisconsinoverlander
Apr 26, 2012 10:24 AM
gustav23
Dec 15, 2011 01:12 PM
DiscoVan
Sep 13, 2011 09:37 PM
