04 coolant tank needed
Old Apr 9, 2013 | 01:12 AM
mark d's Avatar
Default 04 coolant tank needed
My coolant tank has a pin hole. I started shopping and I found a tank that fits 99 to 02 for $60 and they have the 02 to 04 tank for $190. I don't understand the huge price difference so I kept shopping. The second place had a tank that fits 99 to 04 which confused me. Then I found Rovers North wants $26 for the tank. Help!??
Old Apr 9, 2013 | 06:53 AM
hmmm... unusual for RN to be the lowballer on anything, a quality product and customer service and great exploded diagrams and old Polaroids don't come cheap. Their site shows that expansion tank is $221.10, model RNI554; and the Proline aftermarket for $79.95. The coolant cap is $25.90. Fits 99-2004 D2.
Alternate suppliers exist, including dismantlers (part out pros, like Paul Grant); and local boneyard (I fly low and fast with the partz vulturez to get at the dead ones early).
A work around to keep you rolling short term is melt that spot with a soldering iron or a nail heated with a flame. You can also melt a zip tie on it, and there are a variety of tank repair goo sold at parts store. Problem with tank repairs is that has pressure just like the radiator. I've seen a bolt and nut put through a hole drilled in the tank, with repair goo.
Old Apr 9, 2013 | 07:21 AM
RANDY04D2's Avatar
Default 99-02 tank.
The 99-02 at Atlantic British for the $60 is the same $190 tank for 02-04. Call and confirm with them. Installed 99-02 tank on my 04 last week. Identical but different part number......
Old Apr 9, 2013 | 12:08 PM
When replacing the coolant bottle, make sure to replace the cap and switch to a 180 degree soft spring t/stat for better cooling.
Old Apr 9, 2013 | 12:36 PM
jafir's Avatar
The old part has been superseded to the new part as noted by this dealer website:
Land Rover Parts - Land Rover Parts Center - Call (800) 574-9217 for Genuine Land Rover Parts and Accessories
Either will work fine. Rock auto has the old part number in aftermarket form for $38.
Old Apr 10, 2013 | 08:19 AM
mark d's Avatar
Hey Savannaha, I was looking at the site wrong. That is just the cap for $26, anyway, they have not called me back. I'll take a look at Rock Auto, thanks Randy. Mike, I replaced the cap and upper hose assembly about a month ago, I'll go ahead and do the thermostat. i will try yiur fuys for the "soft spring" thermostat. Which switch? Thanks to all of you!
Old Apr 10, 2013 | 04:53 PM
mark d's Avatar
So I got on Rock Auto's site and the only parts listed were:
2004 : LAND ROVER : DISCOVERY : 4.6L V8 OHV : Cooling System
Old Apr 10, 2013 | 04:58 PM
jafir's Avatar
You have to look up a 1999-2002. Or search by the "old" part number, ESR2935
Old Apr 10, 2013 | 10:44 PM
mark d's Avatar
I ended up calling Mike's guy, Paul PTSchram and it is on its way. Thanks for all the help
aguison
Nov 16, 2012 09:29 AM
twalter87
Sep 9, 2007 08:47 AM
bonedoc
Mar 21, 2007 10:04 PM
dchyun
Oct 19, 2006 04:20 PM
